My ET112 installed as a grid meter only powers on (the left light green) when my house is exporting. The rest of the time there are no lights on. Is this normal behaviour? Or is my ET112 faulty?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Thanks for the reply. I was using the second wiring configuration from the manfacturers manual https://www.gavazziautomation.com/fileadmin/images/PIM/DATASHEET/ENG/ET112_DS_ENG.PDF. However, after you comment on the incoming neutrals I realise my neutrals were back to front. Not that that really should make a difference given both are marked N.
Anyway to avoid any doubt I switched to the first configuration shown in the manual you pointed to. See the new image below. Note the blue and brown blocks go off to the consumer units.
I still have the same issue that the ET112 only shows the lights when the house is exporting.
40 People are following this question.
