bertcy avatar image
bertcy asked
Firmware update, Victron connect and MK3
Greetings Victron community,
Is it possible to update an existing Victron system three-phase parallel system using Victron Connect and update all three inverters at the same time.
Kindest Regards.
firmware update
nickdb avatar image
nickdb answered ·
Yes, all documented in the manual:
https://www.victronenergy.com/media/pg/VictronConnect_configuration_guide_for_VE.Bus_products/en/firmware-updates.html#UUID-442a9585-0ebc-8d71-f036-12f91012e24e
Config has to be reapplied like most other updates.
Also can be done via remote VRM update.
Please thoroughly read the process so you don't end up with problems,
