Im setting up a new system and have had to convert the VE.CAN port to 500bps VE.BMS to see the battery im using on the CCGX , problem is im using a Multi RS solar48/6000 inverter that can only communicate over VE.CAN , is it possible to communicate with the BMS one VE.BUS ?
