Good day. We have an interesting case whereby a system with battery discharges when running on ESS (with and without battery life has no impact). The minimum SOC is set to 30%. There is no Dynamic ESS loaded and we are one firmware version 5.08. the system is 3 x Multiplus II 5000's in parallel. There is 5 x 5.3 kWh battery backup installed. See the screenshot below. Any idea why the PV would not carry the load and the battery discharge the bare minimum?
