I have a Quattro 48/8000/110 not accepting power from back up generator
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Take a look at the generator faq linked.
You may also need to bond ground and neutral
"Related Resources" pop up on the right side of the page for these sorts of things, including the FAQ and some other helpful info
Hi @Brian Rowan
Take a look through this.. https://www.victronenergy.com/live/multiplus_faq
There are other things that may come into it too, but try these first. 'Weak AC' often helps, but comes with downsides and is usually indicative of other issues. Hz too can be an issue with cheapo poorly-regulated gensets, but just a rev tweak with a screwdriver can often fix that. Good Luck..
Turns out system doesn’t like the power coming from the generator even though voltage and hertz are in normal range, connected another generator to the system and it all works fine.
I should add that the generator and solar were working fine together for a year and a half , tgen one day system just doesn’t like the generator power anymore.
GX - Generator auto start/stop
42 People are following this question.
