If I create a VE.Smart Network in a Smart MPPT and then let a SmartShunt join this network to share voltage and current info. Can I read the SmartShunt current via ve.direct from the MPPT or do I need 2 ve.direct to USB cables and read each device. Which would be annoying because the information is already shared via BT. Btw, I read the ve.direct protocol manually with a raspberry pi.
Best regards,
Michael
