samsamsamsamsam avatar image
samsamsamsamsam asked
Homebridge or similar solutions on Cerbo GX for Apple Homekit PoE Camera Solution
Hello
I like to install, Homebridge or similar solutions on Cerbo GX, for a Apple Homekit PoE Camera Solution.
Is that possible?
With my own Raspberry Pi on which Homebridge is installed, this should not be a problem.
But I would like to run Homebridge directly on the Cerbo GX to save power and money.
The PeE cameras should only be available in Apple Homekit to store the entire stream in the iCloud for 10 days free of charge.
The motion detection etc. is done by the Reolink camera software on the camera itself, well enough with the Reolink app.
So the demand on the computing power of the Cerbo GX should not be very high.
I currently have the normal Venus firmware installed and only three devices connected.
Thank you
Samuel
cerbo gxVenus OSNode-RED
samsamsamsamsam answered ·
I found this.
https://flows.nodered.org/node/@plasma2450/node-red-contrib-homekit-bridged
Am I on the right track?
(Reolink or other) RTSP livestream cameras, integrate into Apple Homekit, via Victron Venus OS (Cerbo GX or others).
Feasible, even for non-programmers, with a little patience and willingness to learn.
Here are the steps I have taken:
1.
If you want to use older Apple devices, take note of this.
https://discussions.apple.com/thread/254934792?sortBy=best
For example, I use an Apple iPad Air 2 from 2014 as an Apple Home Hub.
2.
You may also need to reset your Apple Home.
Use this one.
http://appldnld.apple.com/iOSProfiles/HomeKitReset.mobileconfig
3.
Test RTSP Livestream and set RTSP Camera IP to Static.
There is a high-resolution and low-resolution stream.
https://support.reolink.com/hc/en-us/articles/900000630706-Introduction-to-RTSP/
4.
Install Victron Venus OS Large firmware on Cerbo GX.
And activate Node Red on Venus OS.
https://www.victronenergy.com/live/venus-os:large
5.
Log in to Node Red with the user name admin and the password for the Victron Remote console.
https://community.victronenergy.com/questions/175440/login-username-and-password-for-first-use-of-node.html
7.
Install and test the node-red-contrib-homekit-bridged v1.6.1.
https://youtu.be/QTK2wM7vCRI?si=NeaiaGohUyiLxVfP
8.
Set up root access on Venus OS.
The default root password is ZZZ.
And free up hard disk space using the script:
/opt/victronenergy/swupdate-scripts/resize2fs.sh
https://www.victronenergy.com/live/ccgx:root_access#partitions_read-only_rootfs_and_available_disk_space%E2%80%8B%E2%80%8B%E2%80%8B
9.
Download and install FFmpeg Static Builds, for ARMHF, directly on Venus OS.
https://www.johnvansickle.com/ffmpeg/faq/
10.
Set up the Apple HomeKit Node Service in Node Red.
Depending on the camera.
https://nrchkb.github.io/wiki/service/camera-control/#-reolink
11.
Deactivate root user access to Venus OS again.
A live stream should now be available in the Apple Home.
If there are problems, it sometimes helps to restart the Venus OS completely by cutting the power supply.
And switching the Apple Home app and the Apple Home Hub on and off.
Otherwise, a re-installation of the Node Red installation can also help, with
rm -rf /data/home/nodered/ && svc -t /service/node-red-venus/
https://community.victronenergy.com/questions/156632/node-red-repairre-install.html
And or
rm -rf /data/home/root/.node-red && rm -rf /data/conf/signalk
https://github.com/victronenergy/venus/issues/809
Use the “top” command in the terminal to check whether there is enough memory and processor power available.
ATTENTION:
The ffmpeg installation and root access will be lost after a firmware update. This must therefore be reinstalled after a firmware update.
Saving the livestream in iCloud and motion detection do not yet work for me.
This could be because the Apple iPad Air 2 is too old.
Or, I still need to install other services, such as
CameraRecordingManagement
Apple HomeKit status
CameraRTPStreamManagement
I have not found any information on this.
If anyone knows more, please reply.
Second way to use almost any PoE camera in Apple Home, with Homebridge and CameraUI.
Since I have not been able to save recordings to the Apple iCloud with the Node Red plugin and get motion messages.
I have now chosen this way.
However, it could be that it was my mistake, as I did not define a motion sensor, because only recordings in which movements are detected are saved in iCloud.
I would recommend the previous method with the Node Red plugin because it is more stable.
However, I have decided to use this method for now.
The motion messages of this method are also worse than those of the camera's own software.
No idea what you can do about it.
Incidentally, Apple Home only saves 7-second clips of movement, which is impractical for backups.
In addition, you can only access the recordings on iOS devices.
So I decided to also use the camera's own motion detection and save the recordings to an FTP server using the camera's own software.
And then to save the recordings from the FTP server to my iCloud using Multcloud
https://www.multcloud.com
I would say that Apple Home with surveillance cameras makes little sense, it's too immature.
The only advantage is that you can watch the live stream and recordings on the Apple Watch.
However, CameraUI offers many functions that might be helpful.
Here are the steps I took:
1.
For example, I use an Apple iPad Air 2 from 2014, as an Apple Home Hub.
2.
Use this one.
3.
There is usually a high-resolution and low-resolution stream.
4.
5.
The default, root, password is ZZZ.
Assign a root password
SSH to LAN, switch on
6.
Log in to Venus OS via a terminal
ssh root@192.168.XXX.XXX
7.
8.
mkdir /data/download
cd /data/download
wget https://johnvansickle.com/ffmpeg/builds/ffmpeg-git-armhf-static.tar.xz
wget https://johnvansickle.com/ffmpeg/builds/ffmpeg-git-armhf-static.tar.xz.md5
md5sum -c ffmpeg-git-armhf-static.tar.xz.md5
tar xvf ffmpeg-git-armhf-static.tar.xz
9.
Copy ffmpeg to /usr/bin
cp /data/download/ffmpeg-git-20240524-armhf-static/ffmpeg /usr/bin
10.
Install Homebridge on Venus OS
npm install -g --unsafe-perm homebridge
https://github.com/homebridge/homebridge-config-ui-x/wiki/Manual-Configuration
11.
Install camerUI for Homebridge
npm install -g homebridge-camera-ui@latest
12.
Start Homebridge
homebridge -I
13.
Close Homebridge again.
14.
Create config.json for Homebridge, with nano, in the folder
/home/root/.homebridge
Check the config.json
https://jsonlint.com
I have used this config.json.
Replace PASSWORD with your camera password
"bridge": {
"name": "Homebridge 5125",
"username": "0E:91:0A:8F:51:25",
"port": 51077,
"pin": "111-11-111",
"advertiser": "bonjour-hap"
"accessories": [],
"platforms": [
"name": "CameraUI",
"port": 8081,
"logLevel": "debug",
"mqtt": {
"active": false,
"tls": false,
"port": 1883
"http": {
"active": false,
"port": 7272,
"localhttp": false
"smtp": {
"active": false,
"port": 2727,
"space_replace": "+"
"ftp": {
"active": false,
"useFile": false,
"port": 5050
"ssl": {
"active": false
"cameras": [
"name": "Reolink",
"motion": true,
"unbridge": true,
"hsv": true,
"prebuffering": true,
"prebufferLength": 4,
"hksvConfig": {
"source": "-i rtsp://admin:PASSWORD@192.168.1.101//h264Preview_01_main",
"maxWidth": 1920,
"maxHeight": 1080,
"maxFPS": 25,
"maxBitrate": 3000
"videoConfig": {
"subSource": "-i rtsp://admin:PASSWORD@192.168.1.102//h264Preview_01_sub",
"stillImageSource": "-i http://192.168.1.101:80/cgi-bin/api.cgi?cmd=Snap&channel=0&user=admin&password=PASSWORD“,
"readRate": true,
"rtspTransport": "tcp",
"maxStreams": 2,
"maxWidth": 0,
"maxHeight": 0,
"maxFPS": 0,
"vcodec": "copy",
"acodec": "libfdk_aac",
"encoderOptions": "-tune zerolatency",
"mapvideo": "0:0",
"mapaudio": "0:1",
"audio": false,
"debug": true
"videoanalysis": {
"active": true
"motionTimeout": 15,
"smtp": {
"email": "Reolink"
"mqtt": {}
"platform": "CameraUI",
"atHomeSwitch": false,
"options": {
"videoProcessor": "/usr/bin/ffmpeg"
15.
Open CameraUI in the browser
http://192.168.1.100:8081
16.
Set cameras in Apple Home
https://support.apple.com/de-de/guide/iphone/iph7bc5df9d9/ios
The settings for other cameras can be found here
https://sunoo.github.io/homebridge-camera-ffmpeg/configs/
If this does not help:
Install homebridge-config-ui-x on a more powerful operating system.
And then copy the config.json to the /home/root/.homebridge directory on the Venus OS and customize it.
If something goes completely wrong
Reinstall Venus OS completely
ATTENTION the link is only for Cerbo GX
https://www.victronenergy.com/media/pg/Cerbo_GX/de/reset-to-factory-defaults-and-venus-os-reinstall.html
