Hi all,
I run a Multiplus II 5000 with an external Cerbo GX, latest firmware as of today is installed.
ESS is configured, does its job fine, battery charging/discharging all works perfect.
The only thing I see is that excess power fed into the grid is not correctly counted in the VRM portal. I have like yseterdaa a few kw feed-in (visible on the grid power as a big negative number) but at the end, the last days it says Grid feed in 0.3kWh. When I manually set the "Grid setpoint" to negative, like 1kw for an hour, it really counts and says 1.3kW later...
Also consumption is counted correctly.
I was a bit confused and thought maybe I checked not properly, nbut after some afternoon full of sun, 100% SOC and permanend 2-3kw excess feed (Ilimitd to 3kw) - it still said 0.3kwh the last 2 days. Sorry, I don't get it...
Any ideas?
