Hello everyone,
sorry if this subject has already being answear.
I have 5 Lithium batteries connect to positive and negative Bus Bars and from each Busbar there is one main wire that goes to the Multiplus, between the negative Busbar and the multiplus I have installed the Victron Battery shunt. So far so good, the battery discharges through the Negative Busbar across the battery SmartShunt and into the Multiplus, then I get a correct SOC reading, But I've installed and connected solar panels through and Victron MPPT that feed directly to the Positive and negative Busbar, in this case the battery shunt doesn't seen to know that while the batteries are being discharge there are being charge by the solar panels. So the Shunts only subtracts the amps that goes through and eventually show 0% SOC, in my case when 235 AmH have being use from the batteries.
Am I doing something wrong?
Thank you
