Quattro 15kW AC2-Output load rating not found in tech spec. What is it?
It maybe there under a different name??
I ma using the AC2-out relay to control the full load output of the inverter -- but need to confirm that the relay will take full load of the inverter output.
Have not found any information in the manual under AC2-Output ratings
I have setup GX to control the output via a relay and AUX port with two programmable assitsancts.
regards
