Hi
My setup has 1 low voltage mppt 150/70 and second MultiRS 6000 Dual tracker
When there is an excess solar - system disables MultiRS trackers, but I'd prefer MPPT 150/70 to be disabled first
Is there any way to change order in alghorytm?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi
Purely out of curiosity - why do you want to adjust this behaviour?
Try setting the target Voltage(s) on the 150/70 very slightly lower than the RS. 0.1V is plenty usually, but you may be able to get away with much less. Nice to have DVCC enabled, so they both see the same V on the battery.
It should work if both chargers are in the same State (ie Absorb or Float), If the RS has dropped to Float earlier then it will restrict itself. Maybe that's your issue..
Also, as I responded above - even with higher by 0.2V it doesn't work - MPPT stays, MultiRS - no
DVCC doesn't directly control Float status, it just helps with system-wide data. You need to check the status yourself.
In your first pic the RS is throttling at 54.43V, yet the 150/70 is not. It must be aiming for a higher target than that..
As there is no direct user control about this, maybe it's time to take a more programmatically approach.
dbus-systemcalc-py/delegates/dvcc.py is the script to "mess with".
There is a function named _distribute_current() that later calls for distribute() and _balance_chargers() functions.
Maybe you can modify to do whatever you want there....
Alex
Use an utility like WinSCP in Windows, and log in as root to see the Cerbo's filesystem.
Then the folder you are looking is /opt/victronenergy/dbus-systemcalc-py/delegates.
Alternatively, only for studying you can look at the Victron's github repository: https://github.com/victronenergy/dbus-systemcalc-py
Voltage difference doesn't work
I'm assuming before MultiRS is fully supported in VRM - this is a tough task to debug and resolve
I can try do this via NodeRED, to disable MPPT when SOC in some condition, but I'm afraid of breaking underlying logic of Victron
55 People are following this question.
