We’ve just installed 660Ah LFP/LifePO4 batteries and the maker suggests charging them routinely up to 90%. We have 420W of solar panel connected through a Smartsolar 100/30 MTTP controller. This is set to the Lithium setting with everything else set to defaults. We also have Multiplus inverter/charger which is also set to the lithium defaults (as far as I know). Naturally, we can switch the invert/charger off at any time but is there a way to tell the Smartsolar to only charge up to 90%? We have a similar issue with the Balmar alternator voltage regulator but that’s another story.
