Full disclosure, I have been fiddling with a few bits recently and may have inadvertently messed something up!
The issue... I have NodeRed both, reading Generator info and writing the Run/Stop state so that when I start/stop the thing manually, my flow will see the change on AC1 and set the generator state as running or stopped.
This makes the GX display reflect the correct state and also increments the runtime counter when the generator is on.
It has worked just fine for well over 2 years now until very recently...
The Modbus configuration in NodeRed hasn't changed and all other com.victronenergy.xxxx queries are working just fine.
I just looked back at an old post of mine a asking how I might go about doing this in the first place and I cant see anything there that suggests I did anything with other setpoints or configuration.
AC1 is set to generator, which is my only input.
