Hey all. I've been trying to work this out for weeks now and can't seem to find a resolution. Hopefully somebody here can help.
I have an off-grid system comprised of the following:
Multiplus II-GX 5000/48
Smart shunt 500a
Smart solar mppt
Poweplus lithium battery bank 12kwh
I have programmed the GX through VE.config and the other devices through Victron Connect with the required settings from Powerplus. The low voltage cutoff on the GX and shunt is programmed to 50.2v, however the multiplus frequently cuts out at voltages higher than that, according to the data I've pulled off the shunt. I've attached screenshots of everything here and wonder if anyone can see something that I can't.
I have recently replaced the multiplus just to see if that made a difference and the issue still occurs.
