Hey everyone. Thanks for the insights:
Environment: 1985 Campervan running 300-watt solar system. 300 ah lithium battery. 22 feet away from the engine.
Components Owned: Victron Energy Orion-Tr Smart 12/12-Volt 30 amp 360-Watt DC-DC Charger Non-Isolated + Victron Energy SmartShunt IP65 500 amp Battery Monitor
Wiring sitting in my Amazon Cart to order: https://amzn.to/3ULAhwO
QUESTION: The old system (much less amperage), had some sort of solenoid/switch in the engine bay. In theory, it would allow energy to flow to the "house" battery once the truck is turned on. I am wondering if I should/need to replace that unit in the engine (if so can you link me to one you recommend on Amazon)...or if the Victron DC-DC unit handles that task (i.e. do I just run the 4guage red power cable directly off my truck's batter directly into the DC-DC non-isolated charger?
Thank you SO much in advance for your insights,
Mike
