Troy P avatar image
Troy P asked
Quattro II shore power wiring
Probably a stupid question, but someone managed to confuse me along the way. I'm installing a Quattro-II 2x120, I've got 50a 120/240 split phase shore power and a 12.5kw generator. Currently I've got lockout selectors for shore and generator on the switch panel. Should I redirect both inputs directly into the Quattro (shore power inlet has a breaker at the plug) or should I go from the lockouts down to the inverter and back up to the panel?
shorepowerQuattro-II
Justin Cook avatar image
Justin Cook answered ·
Technically that's between you and your installer/electrician to decide depending on how you want your system to behave, but the installation instructions for the Quattro-II are here (I've specifically linked to the AC connection section): https://www.victronenergy.com/media/pg/Quattro-II_12-24V_3kVA_2x_120V/en/installation.html#UUID-a5b7d70e-e531-d5c1-996b-586bd5056af3
Quattro II Product page
Quattro II Online Manual
Pre-RMA bench test instructions.
