Hi all,
Recently installed a Victron Inverter RS Smart Solar with a FW eTower (10kWh), off-grid.
I am using a Cerbo GX and used the special "Victron" comms cable supplied with the eTower to connect the eTower CAN port to the Cerbo's BMS-CAN port.
In the Remote Console I programmed the BMS-CAN port profile to 500kbit/s
Then connected the Inverter RS VE.Can port to the Cerbo VE.Can port with a straight through ethernet cable (and put terminators at both ends of the cable in the open RJ45 ports).
In the Remote Console I programmed the VE.Can port profile to "VE.Can & CAN-bus BMS (250kbit/s).
The Inverter RS display shows "Info: BMS Switched off", and the eTower is not being recharged from the solar.
The inverter part of the Inverter RS is working fine and giving 230V output.
However, the in-built charge controller does not seem to work and is not charging the eTower.
Any idea what I did wrong?
Thanks for your insights! :)
