helimech avatar image
helimech asked
Touch 50 Readings
Attached are 2 pictures, both are with no shore power. One is with the solar power turned off and the fridge turned on being powered by the house bank (via the Multiplus inverter). The second is with the solar on powering the fridge and the excess going to the house bank. My question is why does the house bank show a positive watt number when its powering the fridge and a negitive number when its getting the excess charge from the solar?no-solar.jpg
cerbo gx
helimech avatar image helimech commented ·
All DC loads are OFF
My System:
Multiplus 12/3000/120
Lynx distributor 1000 DC
Cerbo GX - GX Touch 50
BMV-712 Smart - VE Direct to Cerbo GX
Orion-Tr Smart DC/DC Charger
MPPT 100/50 SmartSolar Controller - VE Direct to Cerbo GX
Kevin Windrem avatar image
Kevin Windrem answered ·
The Victron ecosystem has always minimized negative numbers and only used them in the battery and when feeding energy to the grid. To that end, Victron has decided that a positive number means the battery is supplying power and a negative number indicates it s consuming power. On the AC input side, a positive number indicates power is being consumed from the grid and a negative number indicates the grid is being fed power from the system. Both of these are technically backwards but that's the way things are.
