Hi fellow Victron enthusiasts.
I wonder if anyone can give me some more ideas of what is going wrong with this install where a 250/100 rev2 is underpeforming:
A bit of history to this install where it seemed everything that can go wrong did go wrong. The setup is like this:
Three-phased simple sistem with:
3 x MultiPlus II 3000VA
Cerbo GX
1 x Pytes 5.12kw LIFEPO4 Battery - E-BOX-48100R
1 x SmartSolar Charger MPPT 250/60 rev2
1 x SmartSolar MPPT VE.Can 250/100 rev2
1 x EV Charging Station 32A
Here is also a picture of the setup:
The solar panel layout is as such:
Solat panel model: Trina Solar 440W - VoC: 52.2 / Isc: 10.67
For context I will fill you in with events that had happened up to this point:
1. We went through three EV charging stations. One we sent back as LED were not lighting up. Dealer had no idea what is going on. Second one shipped LED display was frozen. Third one we got was again with LEDs not working. Turned out thanks to Lucian from Victron Staff here it was a software bug. Eventually now it is working. We still have an issue where EV charger is dubbling up the AC Load figures. This was also confirmed by Victron Staff it will be resolved in upcoming VRM release.
2. The 250/100 original MPPT after a few days just died. Very important information now for upcoming topic: With this MPPT the same string performed well 5kw+ outputs. This had to be of course replaced with a similar 250/100 which for the last two months works but with limited output.
250/100 stats as of today:
250/60 stats as of today:
As you can see yesterday the solar charge throughput is same on both 250s roughly:
Wonder if anyone here can give me some ideas of where to go next.
Greetings from Romania!
Dan
