From reading the manual for my new MultiPlus 12-Volt 3000VA 120 Amp 120V, I see that there are two RJ-45 ports described as: "2x RJ45 connector for remote panel and/or parallel and 3-phase operation."
Do I connect one of these to the VE.Bus on the Cerbo-S GX? Does this use a standard Ethernet cable?
TIA,
Eric
