My system looks like following:
* Easyplus 12/1600/70 - 26…..
* Cerbo GX
The devices are connected through the VE.bus port and are running on the newest firmware.
On the cerbo display I can see the Easyplus and the current state, but only when the physical switch on the easyplus is turned on. Otherwise the easyplus is visible but the state is shown as „unknown“.
I want to turn on and of the easyplus through the cerbo. As I see it, that should be possible. I tried all three ways on the dip-switch. (0/0 remote, 0/1 default, 1/0 multi control), but the physical switch is always overriding the setting.
Current setting is:
DS1=1
DS2=0
Easyplus switch is OFF
Cerbo setting for the multi is ON
-> easyplus is OFF
When I put the Multi switch to ON, it turns on.
Easyplus switch is ON
Cerbo setting for the multi is OFF
-> easyplus is OFF
I need the Easyplus to be turned off when the cerbo is turned off.
Also when I disconnect the ve.bus cable, put dip 1&2 to off (remote 3 way switch) and try to use a remote switch and connect terminal 2(gnd) and 3(on) nothing happens when the multi-switch is turned OFF.
To sum it up I don’t get, why only the physical switch is working to turn on the easyplus.
Can somebody please help?
