groningen avatar image
groningen asked
Parallel within a solar string
Background:
I have three 605w panels in series that produces roughly 120V peak at 18A (3s1p). They are running on a 150/45 mppt.
The problem:
Early morning, I have a chimney shadow that sweeps over the panels. It covers roughly 1/2 to 3/4 of a single panel during sun rise. This shadow is present for 2 to 3 hours as it runs from panel 1 to 3.
My Question:
Due to limited space, I cannot run 3S2P (total 6).
So can I add one more panel and parrelel it with one panel i.e. 2 panels will work in parallel but still produce the ave voltage of 120V (40v per panel connection) as if I still have three panels.
Effectively, I am trying to mitigate the shadow effect on a single panel by "picking up the slack" with the 4th panel in parallel.
Will the Mppt be ok with it (Two panels produce 18A and the other 2 36A ?
I can add a picture if my explanation is not clear.
I know the internal diode of the panel switches "on" to bypass the shadow PV cells so effectively, their is also a "weak" amp reading from one panel (as the shadow sweeps from one to the next panel).
Happy to hear your thoughts
MPPT ControllersSolar Panel
Duivert NL avatar image
Duivert NL answered ·
You can but remember the lowest current will determine the overall max current
See also: https://www.victronenergy.com/blog/2015/11/10/connecting-different-sized-victron-energy-pv-modules-series-or-parallel/
and chapter 4.12
https://www.victronenergy.com/upload/documents/The_Wiring_Unlimited_book/43562-Wiring_Unlimited-pdf-en.pdf
Michelle Konzack avatar image
Michelle Konzack answered ·
Yes you can, BUT you need a Diode/Rectifier on bot parallel panels, otherwise the shaded panel will be cooked by the non shaded one.
maa avatar image
maa answered ·
Anti-return diode on the positive cable calibrated according to your amperage
kevgermany avatar image
kevgermany answered ·
This is highly unorthodox.
I don't think you'll see any advantage unless you parallel it with the panel nearest the MPPT. Otherwise you'll be limited by the max current of a single panel.
MPPT Product Page
MPPT Error codes
