dear fellow boaters and engineers
Here is what I asked Victron and would like detailed professional answer based on the facts and data....
Dear Victron
Please forward my question to your experienced engineers.
I am a power electronic engineer. I have been working with the boat and Yacht industry for over 25 years. Last few years small boats with and outboard engine started putting Lifepo4 batteries mainly because of anchor lock mini electric engines (like Minkota, Garmin, Haswing etc)
I want to make a workable setup by starting outboard with your 330Ah battery that has a peak of 400A. That current is sufficient for the vast majority of small outboard engines.
I know that starting an outboard with Lifepo4 battery is not recommended but here we talk ONLY about your biggest 330Ah battery and setup that can work with it.
Will you please carefully look at my proposed setup and answer the basic question:
CAN ALTERNATOR PORT OF BMS 12-200 BE BRIDGED WITH SYSTEM+ PORT?
As the current direction of the system+ port is OUTward I presume that there will be no negative consequences of this setup? After the outboard has started it will continue to charge the battery through the alternator port?
If this setup proves functional I am sure your sale of 330Ah batteries will skyrocket along with BMS 12-200.
Please respond with the highest quality answers.
Thank you very much
Looking forward hearing you
very best regards
Jean Maro
