Hello, please experienced advice. I have an incompatible REVO VM II hybrid inverter, so nothing from Victron. To monitor the battery I use a SmartShunt 500 and at the same time a JK-BMS (via dbus-serialbattery) connected to the CERBO GX.I can see everything on REMOTE CONSOLE, but I only have SmartShunt or JK-BMS on VRM. I would need to get a SmartShunt there as a controller and a JK-BMS some control data for display only. I couldn't find anywhere how to do this. I only found an option when some inverter is connected to load into the VRM configuration (Victron only) Does anyone know of a solution? Something like connecting a virtual device and sending it parameters from the JK-BMS.Thanks for the advice.
