Good Morning - first question! I have two big panels on my camper. They they are matching 310w, 40.29 Voc, and 9.93 Isc. If I connect in Parallel I get:
- Temperature Compensated Array Voltage: 101V
- Controller Output Amperage: 43A
- Array Short Circuit Amperage: 9.93A
And if in series I get:
- Temperature Compensated Array Voltage: 50V
- Array Short Circuit Amperage: 19.86A
The max fuse rating is 20W.
I got the info from using the calculator at explorist life.
So my question is do I do with the cheaper 100 50 and go in series, or the more expensive 150 45 and go in parallel? I will be charging a lithium battery - still debating 280ah or 460ah.
Thank you!
