i'm using the venus_kostal_pico script in Venus OS 3.30 with a Kostal Piko 5.5 NG.
Means i use version 3 in the INI file.
Until now it works.
Following question, how can i change the display name ?
in the configuration i see the value "Piko55"
But in the front view on the panelview i see only a " - "
in which file of the GuiMods will the name be generated ?
Many thanks
