I have a external energymeter ET112 grid connect to pin 1 and multiplus to pin 2 > AC-in.
both neutrals connected to right pin N on ET112
No connections on AC out 1 and 2.
Mains go to AC-in no connections on AC-out 1 ore 2
Multiplus get volts from grid but no loads (very low 40 a 50 Watts)
Ess > external meter and is seeing by the Multiplus.
When i switch to charger/inverter the same happend, very low watts 40 a 50
Do i have a setting misplaced ore do i have a faulty Multiplus 2 GX
I live in the Netherlands and have selected (Europe for grid connection)
When i manualy set battery loads to grid i have a correct reading( set to 1500Watts, i see 1500 watts) pushing to grid.
I don't no anymore wat to do...
