Hello guys. Just mounted MPPT 75/15 with two 120w pannels in paralel. When i finished mounting, it was almost sunset and i was getting around 16V and 0.0 A from PV. Battery voltage was 12.9V, it is brand new VRLA AGM 140 Ah battery. I know that it needs to be at least 5V difference to activate the charger, but i have few questions. First of all, if I'm using victron connect app to set up charging, do i need to remove jumper link (little black one)? Im asking because i forgot to remove it today, and in manuals it says if using app then you dont need jumper link and remove it. Second question is, what settings to use,(should i activate expert mode) absorption and float voltages, asorption time etc. I didnt get notes from manufacturer so if anyone knows what settings to use, it would be helpfull. Best regards to all!
