I am planning installations on small workboats and am looking into the newer battery systems. I am quite hesistant to go for the lithium gear with BMS's and all data ports and so on. If I look at the Lynx BMS for example it is IP22.
How do you experience the durability of all this gear with condensation, sometimes due to a metal boat, sometimes because of water in the hull, etc. I have the feeling the equipment is quite fragile and more suitable for larger yachts and workboats, where the technical area's are more separated from the wet area's.
Would love to get some feedback here!
Thanks,
MG
