The input frequency range of MULTIPLUS-II 3kVA 48V INVERTER CHARGER is between 45-65 Hz (refer to the manual). Due to the grid instability in Tanzania's Mara region, it is possible that the frequency drops below 45 Hz. If this situation occurs, what will happen to the inverter?
