roscoe avatar image
roscoe asked
500A Smart Shunt dead
I installed a Victron 500A Smart Shunt to monitor a 100AH Lithium battery several months back.
it worked fine for 3 months, but yesterday when I tried to connect via Bluetooth it was not visible. Upon further inspection I noticed that no lights were visible on the unit. It appeared dead.
i tested the voltage at fuse and unit connection point and it was fine.
i have disconnected and reconnected the unit with no change.
it is getting power and is wired correctly so I’m assuming unit failure.
Any suggestions or comments are appreciate.
thanks
SmartShunt
@Roscoe
Weird, but, yeah. Sounds like it died.
Definitely a return to supplier issue.
Paul B avatar image
Paul B answered ·
yes return it to your supplier for chaecking and replacement if needed
roscoe avatar image
roscoe answered ·
Yeah, pretty sure it’s failed.
I’m in contact with supplier, thanks guys!
