aragonx avatar image
aragonx asked
VRM phoenix inverter want to show kWh per day
I would like to see the kWh inverted for my Phoenix 1200va inverter per day and per month in my VRM portal somewhere. Is there a widget or way to do this? A report would be fine.
VRM
Alexandra avatar image
Alexandra answered ·
@aragonx
Is this the ve direct model?
For ve direct under system you can load AC consumption widget.
But you won't get cumulative totals like you do for solar unless you add an energy meter or get a ve bus inverter or an RS.
