I have built the first 3-phase system with 2 MP-II in parallel on each phase and I would like to get a confirmation whether the LED lighting is as should be as there is different LED light combination on multipluses within each phase.
When the system is set to Bulk, the LED lights indicate as follow:
Inverter #1 on L1 lights: Main on, bulk on, inverter flashing
Inverter #2 on L1 lights: Main flashing, inverter flashing
Inverter #3 on L2 lights: Main on, bulk on, inverter flashing
Inverter #4 on L2 lights: Main flashing, inverter flashing
Inverter #5 on L3 lights: Main on, bulk on, inverter flashing
Inverter #6 on L3 lights: Main flashing, inverter flashing
Thank you for your comments.
