System: MPPT 100/30 and 150/70
Solar arrays A: single 200w panel, array B has 2s2p 200w panels. These are Rich Solar 24 panels with open circuit voltage spec of 45.4v
With array A on the 100/30 and array B on the 150/70, the 100/30 show a voltage of 45.2 and amps of .07. The 150/70 shows voltage of 72.9 and amps of 7.59.
If I swap the arrays, so B is on the 100/30 and A is the 150/70 I get voltage on the 100/30 of 89.6 and amps of .04 the 150/70 shows voltage of 36.8 and amps of 3.85.
So it appear that the 100/30 is reading voltage to high or cause the panels to see an open circuit?
Both MPPT controllers report correct battery voltage and both are in bulk mode.
Panel specs
Array A: on 100/30
Array A on 150/70
