glennbtn avatar image
glennbtn asked
12v Dc charger question
I see with a Victron charger you have a power supply mode. Now I have a camper with victron all set up but also have a day van where I have a Ecoflow. Now the Ecoflow only has 10amp output on 12v. Can I use a 30amp Victorn charger on power supply mode via 240v socket to run 12v to the fusebox to run light and a fridge ok?
I have been told to use a switching power supply from Amazon but these look unsafe as the back is all exposed. I would rather use something of better quality such as the Victron is possible.
If I can use one does it run at 30amp draw all the time or does it increase the output as needed
Thanks
battery charging
kevgermany avatar image
kevgermany answered ·
Yes.
Output depends on load. In power supply it's adjustable constant voltage.
