I have read too much and I am now utterly confused!
I have three Victron panels (each with the following specs):
215W
24V
max. V 37.4
VOC 45.82
max pw 5.75
I was going to install in parallel and use my mppt 100/50. I now think in series (645W) would be better suited for my set-up (panels on roof, no shade, UK). The victron mppt calculator suggests the mppt 250/60. I understand that the 100/50 cannot cope with the combined VOC of ~140 (3x 45.82) but 250 seems overkill? Why not the 150/60? Am I right that the amp (5.75) will remain the same?
I will have to run cable for approx. 9 meters (30 feet) and I have two 130ah AGM batteries.
Questions -
Which mppt? Do I really need the 250/60?
Cable strength if in series? The amp is pretty low - would a 8AWG be enough?
Batteries in series or parallel (12V or 24V)? What's best?
I would really appreciate some help/corrections/advice!
Thank you!!!
