Hello all,
I'm looking to install an Orion 12/24-15 DC-DC charger. I'm going to install the current model (15 amps) but wire it large enough for the future Orion XS 12/24 which I assume will be 25 amps (24V)/50 amps (12V).
I have a 33ft RV and the 24v batteries are in the rear (almost all the electrical system is located in the rear on my rig). The Orion can take up to a 4 awg wire. However, when calculating the voltage drop, I would need roughly 1/0 AWG wire to keep the voltage drop below 5%. At 4 awg, the voltage drop is 10.6% dropping the voltage from 14v down to 12.5v. The draw goes from 50 amps to 56 amps.
Is it a big deal to use 4 awg even though the voltage drop is 10%?
If the voltage drop is a big deal, do I simply terminate the 1/0 at a bus bar and then run a short 4awg from the bus bar to the Orion?
Thank you all for your shared wisdom.
