I am currently purchasing and procuring items for my solar install. The setup is as follows:
1. 22 Longi 570W panels (12 panels on the 100A, 10 panels on the 85A)
2. Two Victron SmartSolar Charge Controllers (150/100A, 150/85A)
3. Victron Multiplus II 5000/70 (230v)
4. Midnite Solar Combiner Box MNPV6
6. 48v 280ah Battery Box from Shenzen Deriy
7. Battery Monitor BMV-712
8. Cerbo GX
I have been trying to find the best way to connect everything together as my funds have been severely depleted using the Lynx Power In and wanted to inquire if i can use the Lynx Power In to connect the two charge controllers, inverter and battery box all on one bus bar. I will place the BMV-712 after the Lynx Power In and a DC MCCB the Battery Box to serve as a disconnect. Can i connect them all together without fuses ? If i need fuses, can i place two fuses for one side and no fuses for the other side but all on the same bus bar ? Thank you all.
