max-payne avatar image
max-payne asked
Victron 3 phase ESS recommended Bypass switch
Victron tells us that in a AC-OUT ESS System a bypass switch is recommended for maintenance reason etc. (which makes total sense).
So which bypass switch would you recommend for 400V (3 phase) ESS?
Everywhere I look I see "400V automatic transfer switch" which have a manual option also.
Give me some options you know are a good bypass please.
Multiplus-IIESS
We normally use a Hager HIM404 or 406.
Others use the Kraus & Naimer KG63B K950 VE2 F437.
