Can I use both Smartsolar MPPT 75/15 and Blue Smart 12v/15amp charger at the same time to charge my 13v 108ah BlueNova lithium battery?
Using battery powering camp freezer.
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Ideally you would want to coordinate charging between them and with one not have blueteeth you can’t use smart networking.
You will just need to be careful with your settings if they are going to operate independently. The blue nova will have a bms, so if you get it wrong it will just turn off.
Ah, missed the Blue smart part.
Check the doc
https://www.victronenergy.com/upload/documents/VE.Smart_Networking/20723-VE_Smart_Networking-pdf-en.pdf
It lists compatible products and limitations.
53 People are following this question.
