I am installing a links power in, links, shunt, VEC and links distributor.
No matter what I do I cannot see the links shunt on my servo GX screen. I have tried replacing the cables with brand new ones, removing all of the other connections from the Cerbo GX (VE B us, VE direct) except the display. I have even replaced the Lynx shunt itself with a new one but still no luck.
All I see is the Shunt LED flashing green indicating "initialization" but no matter what I do, it does not show up on the Cerbo. I have also tried setting the VE CAN configuration to make sure that it is set for Lynx Ion 250 CAN and still nothing.
I am getting to my wits end – am I doing something wrong? I've read the manual about six times and there is very little detail about anything related to VE Can. I have followed the schematics and everything I can read in the manuals.
Does anyone have any suggestions for what I could try next all input is appreciated.
Thank you,
David
