5kw inverter 5.2ah lithium battery 150/85 mppt
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
You probably mean 5,2kWh right?
A little bit small for a 5kVA Inverter.
However, I assume, your MPPT 150/85 is already connected to the Battery or Busbar and configured correctly to charge the Battery.
The Windcharger is simply connected in parallel to the MPPT as long as it support the charging of your Lithium Battery (which most don't).
Oh, I forgot one thing:
The MPPT 150/85 deliver up to 2,4kW and the Battery should be at least 3 times bigger, hence 7,2kW.
Better is already to add a Battery of the same type to it.
41 People are following this question.
