I'm sure the answer is somewhere but with Multi-2 often referred to as a plain Multi its hard to be sure.
Is it legal to use shore power/hookup to a Multi-1 (NOT a Multi-2)?
There are quite a few boats and campers with Multi-1 battery systems on board. Are these actually UK legal and if so what are the required settings to be so? I imagine "Feed-in is absolutely not wanted," should be set, but should anything else?
Obviously generator/max power drain etc needs setting.
