I have an old (2013) Lynx Shunt with VE-net connection to Blue Power Panel (and VE-bus to Quattro)
I want to replace the BPP with a Cerbo GX to connect to the new Quattro with firmware xxxx506 but the Cerbo has no VE-Net connection.
Can I use the VE-Net to VE-Bus converter VCC000200000 (or older version VCC000100000) to connect the Lynx to the Cerbo so it can read the current/voltage/SOC of the batteries?
Other option is to replace the Lynx Shunt with the new VE-Can version, but that is much more expensive than using the VCC (if it works).
