justin-steinmann avatar image
justin-steinmann asked
MPPT performance differences
We are in an off grid situation using an 5Kw Easysolar 150/100 and recently the solar charger stopped working and was replaced. I have noticed since the unit was hooked back up that the performance of the charger isn't quite the same as the old one. Meaning that on a day that the old changer would provide 4500W, the new one is only producing 3800W, for example.
Is there a reason this could be happening? I just assumed the performance of the charger was dictated by the solar irradiance and nothing else..
Thanks for any input advice in advance.
MPPT Controllers
Alexandra avatar image
Alexandra answered ·
@Justin Steinmann
I would check all the connections and assembly.
If the connections and wiring are not quite white same then there will also be a difference.
Since the entire set up was disturbed including its guts that is where to begin. Besides a firmware update.
nickdb avatar image
nickdb answered ·
Maybe also connect to the mppt and confirm it is setup right - no current limits etc.
