which of the connection types of the VM-3P75CT ethernet/ ve can will result in a faster regulation for a ESS with Cerbo and a MP 2 5000 ?
Will they be the same or are there differences? I understand that ethernet may be not as stable caus of network/ip problems
Edit: Is there a recommendation from victron which connection to use if i have the choice?
