Could someone please clarify whether the grounding terminal on the side of the housing needs to be wired in? The output on the charge controller will be heading to the pos + neg on the leisure battery and from there the negative terminal will be ground to the chassis of the van, in this instance, is it necessary to ground the housing on the charge controller as well? If so, what size cabling would be required?
Many thanks,
Joe
