Hello: I have a newly installed Cerbo GX and I have been trying (without success) to correctly set my local time. I just noticed that the UTC on the Cerbo is incorrect - it is an hour slow (it says 22:34, when the correct UTC time is 23:34). My location and time zone are set correctly on the Cerbo, but because the UTC is incorrect the Cerbo keeps setting my (manually set) local time incorrectly (since it should be UTC -7, but since the UTC is off, so is UTC -7). I cannot correct or manually set the Cerbo UTC.
Any suggestions?
Lawrence Talbot
