In setting up our system it was clear that the MPPT charge controllers could be set to BMS control, and this works fine with the battery BMS connected to the BMS can port on the Cerbo… however it is unclear if the inverters also follow the BMS in charging from the generator. Is there a setting to make this happen, does it happen automatically, do you have to add an “Assistant“ I’ve been unable to find anything in the manual that indicates how to proceed. Thanks!
