I have just added a second Fronius inverter AC coupled to my installation.Its not showing up on the graphic or calculating correctly.
However if I look at device list it shows up in the device list. They are both set to "Show = Yes"
Any hints on what is going on or why this is the case ? When the load matched the output of the smaller 3kw unit it just read a 0 AC Loads on AC out 1, and the second Fronius was showing as going to the battery. In screen capture above it shows 2077kw load, 3704w PV inverter and 1744w to battery, yet the sum of the available PV in the second screen shot is 5045w. If you remove the Ac load from this value, then 2968w should have been going to the battery.
I suspect the AC load was higher by the 1355 watts of PV inverter 2 plus a little more 200w ??
Thanks in advance.
